My Creality K2 Pro arrived with a single-sided build plate, not the advertised double-sided PEI plate . Has anyone had the same issue?
Apart from that issue, been loving this printer.
I guess you can use both sides? Mine came with a goldish colored plate, textured on one side and a smooth side. Never used the smoothe side. Not sure if it’s PEI on the smooth side… How can you tell..?
Yes, mine also came like that, but in most of the unboxing videos it came with both textured sides. Cheers
こんにちは。私も片面でした。歪プレート不具合でプレートに傷がついて交換品が送られてきました。交換品は両面PEIプレートでした。反対の面はどのように使えばいいのか?迷っています。 東京より。うまく翻訳されると良いのですが・・。
I just realized mine did come with two plates. A single sided textured plate and a double sided textured one. Forgot all about it as I had it stashed and haven’t used it yet. Also came with a spare extruder assembly.. ![]()
Hi, you were lucky, you received the pack that is sent by Creality to YouTubers for testing and review. Regards.
