how can i change the ip address in print 6
I’m on a K2, but had a similar issue. I never found a place to change the IP in the Print 6 software, however, it was accessible from the local touch screen.
i found it in the touch screen but it would not allow me to change it, Fortunately, i found a scan button in print 6 and this found the correct ip, so I’m good to go. Thanks for the response!
The IP address is assigned by the Wi-Fi router. The IP address can only be changed in the router settings. (You have already been told how to find the printer’s IP address)
