I don’t really hear those sounds but a ticking sound means generally that the nozzle is jammed or not hot enough..Or that you’re printing too fast for the filament (Max volumetric speed)
Or if it only happened during first layers, it could be related to a wrong Z-offset…
Not only in the first layer, I did increase the retraction length from 0.8 mm to 2mm I will try to change it back and see
It’s not related to retraction.
And it’s only happening with this filament, right ? PETG or PLA ?
