Nebula camera orientation mirror
Hi,
I bought the Creality Nebula camera and installed it straight away. Now I have the problem that the camera rotates 180 degrees on the standard Creality web interface. So everything is upside down.
If I adjust it using the settings or Fluidd, it doesn’t change on the simple Creality web interface.
How can I solve this problem?
Best regards,
Chris
:upside_down_face: …
Hahahahahaha!! Funny!
Your camera is up side down. Just swivel the camera 180 degrees in it’s bracket and it will be the right side up.
Have a look at the camera face and see whether the writing on the camera is up side down.
Probably your camera can be upside down, but…
For some people searching in the web because the brackets you use make the camera be upside down, you can grasp the 2 tabs that hold the Z axis swivel (they hug the camera on the sides with pins that go trough holes so you can swivel it), pull then apart, them remove the camera from them and reinsert it inverted, so that you can mount in your inverted bracket but don’t have the image mirrored.
You cannot swivel the camera upside down because of the usb cable location, it would be damaged if you tried to swivel it until turning it upside down.
as far as i know, there is no way to mirror the image in software ( creality print or website or app)
I also have creality nebula, what i did was carefully tool it out of its swivel mount and put it back in the other way around, effectively making it the right way up
