Hi folks
I moved to a new apartment recently and had the printer packed using the original box.
Now moving the head in the X or Y axis does neither look, nor sound very healthy. Take a look:
In the video, I am moving the head using the UI a few times along X and a few times along Y.
Can anyone give me a hint or guide me to a solution? This is my first 3D-printer, so I have yet to learn more about it.
With the unit turned off, it does take some force, but not much. But it is impossible to move either just along X or just along Y. It only moves diagonally and it appears that the upper belt in the back is stuck.
Found it - external bolt previously used for holding the filament sunout sensor and mount. Removed it when installing the CFS, and replaced it without thinking of the extra width the mount had provided. Runs smooth, have done a number if prints without issue since.
