Using LightBurn 1.6.03. After doing Calibrate Camera Lens, I attempt Calibrate Camera Alignment. This is supposed to create a test pattern, but nothing happens. The power indicator flashes green. If I cancel and then close LightBurn, it pops up a message saying “Still streaming to device”. The red Air indicator on the laser flashes red, but the pump and fan are both running.
The Frame button sometimes works and sometimes doesn’t.
Lightburn logs this on startup:
Waiting for connection…
usb connect succeed
usb connect succeed
ok
[VER:1.1f.20220810:]
[OPT:VHL,127,65536]
Target buffer size found
[software versions: CV50-Pro-MASTER-Release V1.0.0 20231204-1353]
ok
Homing
ok
Where can I find out what the different colors mean? It is sometimes solid white and sometimes solid blue, but mostly flashing green.
