New here: how do you turn a photo of an object into a printable model?
Hi everyone, I’m new to 3D printing and to this forum. I have a small ceramic figurine (and a broken clip from a lamp) that I’d love to print copies of, but I only have photos of them and no 3D files.
What workflow do you use to go from a photo of a physical object to a model you can actually slice and print? Is a photo enough, or do people usually need a scanner or need to model it by hand? Any advice on where a beginner should start would be appreciated.
The TL;DR answer is that if you’re new to 3D printing, what you’re attempting is a daunting task even for seasoned and experienced hobbyists but not impossible if you’re motivated to learn
_______________________________________
Recreating a mechanical, dimensionally specific part from photos is a pretty advanced topic but it can be done if one takes care to specifically take measurements using specific camera angles with length references such as a ruler in the picture or some other object such as a coin or object that can me used as a reference for scale. However, this assumes one has access to CAD and the knowhow of recreating drawings from these reference photos. There are plenty of YouTube tutorials out there.
However, a broken piece of art such as your figurine, even with a high end 3D scanner is another matter. 3D scanners create meshes, not parametric drawings - lines, planes, arcs and circles. If these terms are foreign to you then there is a large learning curve to climb and it can take many hours to get the object you are trying to reproduce into a format that can be printed.
Here are two YouTube videos from the same creator. The first video show how he photographed an opening on a piece of machinery and mate a form-fit component for it in CAD. This video I liked because it shows the technique of photography using a scale and then basing the design from those images. He has more than just this one video on this topic but it is a good starter.
https://www.youtube.com/watch?v=noYuQlQN8pw
In this next video, he shows how to use an obsolete Microsoft Kinnect sensor as a scanner. Don’t get hung up on age of the video as the techniques of managing a mesh haven’t changed much in the last 15 years. The process is like this:
  1. Scan image
  2. Import into a Mesh file – i.e. is an STL file is one of many mesh file formats
  3. Fix the mesh files to remove any holes which will cause errors in the slicer \
  • this process can take literally hours and there is no guarantee you will find all the defects.
  1. Convert or export the file into an STL file for your slicer.
    5)… and this is the most important step[click to view]:
Pray that this even works
https://www.youtube.com/watch?v=H03kx514X2Y
