So everyone knows I am 67 and decided to teach myself 3d printing and scanning 4 months ago so I am learning I bought a V2 Neo that only prints on the far right of the print table and only if I slice it on far left side of the print table. When I press LEVEL it only does 4 points on the far far right side of print table. I bought another brand printer and have not had a fail print yet around 25 prints so at least I still like printing if it was up to Creality I would have gave up months ago
Sounds like you might be having a problem with the x-axis limit switch. I’d investigate that. If it is printing to the right when the x-axis zero is to the left something is not registering correctly. Could be an error in the config file that is offsetting the x zero position perhaps.
I am unfamiliar with 3d printers do you know if I can get my hands on a schematic or wiring diagram
Not sure that a wiring dig will help you. Sounds like you have a offset issue in the code somewhere. The limit switches are also something to look at.
If you are printing offset on the bed to where it’s expected there is an issue with the home register ie: the head doesn’t know the correct dimensions of the build platform or where to begin.
I’m only about a week into 3D printing but I believe I have a decent grasp of the mechanics through screwing up a lot.
