Next question on Ender 3V3 Plus
Got my Ender 3V3 Plus delivered today and assembled it. Now first question:
I pushed the teflon tube into the hole on the print head. But now it is stuck, can’t pull it out without also pulling out the silver piece. What am I doing wrong?
The USB stick that came with the printer doesn’t work on my PC as a normal USB storage devie.
Anyone else having similar problems?
You need to push the little round white holder down while removing or inserting the tube…
Does the USB stick work in the printer…?
It depends on how the USB stick is formatted. If the size of the stick is up to 32GB, it needs to be formatted as FAT32. Anything above 32GB should be formatted for NTFS. FAT32 should run on most systems unless the USB stick holds very large files
Thank you, I will try this when my print is finished.
The problem is that the Linux kernel detects the stick as an USB storage device and the next message is that the media is removed
[ 4345.827037] usb 1-6.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4345.856962] usb-storage 1-6.3:1.0: USB Mass Storage device detected
[ 4345.857169] scsi host6: usb-storage 1-6.3:1.0
[ 4345.857328] usbcore: registered new interface driver usb-storage
[ 4345.861378] usbcore: registered new interface driver uas
[ 4346.879574] scsi 6:0:0:0: Direct-Access     NAND     USB2DISK         0.00 PQ: 0 ANSI: 4
[ 4346.879983] sd 6:0:0:0: Attached scsi generic sg5 type 0
[ 4346.880769] sd 6:0:0:0: [sde] Media removed, stopped polling
[ 4346.881392] sd 6:0:0:0: [sde] Attached SCSI removable disk
So this is not how it is supposed to be. Has nothing to do with partitioning, I’m not even able to access any partition table.
I had the same issue. I got a SD-USB converter + Mini-SD. I removed the mini-sd to put it into my V2 Neo. The whole SD got destroyed. There is no fixing that unfortunately. Best thing to do is buying a new one
Must be a running theme for Creality printers. My V3SE would quite happily devour SD cards, so glad for the Sonic pad, probably paid for itself in cards.
