Hi, My K2 PRO can not select filament in
CFS when print from USB flash drive
but work normal when print from local file.
Which firmware do you use?
As not everyone uses the same version, it could be version related
Continuing the discussion from No filament selection in CFS if print from USB :
Hi, I am using the latest update firmware and this problem happened soon after I am updated.
the other problem is now I can not print via WIFI , the machine take the file but it did not print so I go to touch screen and print from there.
Is anybody have the same experience like me? and how to solve this problem?
This time I try to reflash firmware with old one maybe work?
