No limits when auto bed leveling
Reset my firmware, when the machine was setting up auto level it seemed to ignore x and y limits. The tool head would crash into the corners and over correct or bounce back. This has made the proving on the right miss the bed. What should I be looking for to correct this?
Update in case anyone else runs into this. I am unable to determine the cause, Instead I disabled the auto level routine before each print and made some adjustments to the errored mesh entries, so they are not so out of line. This seems to be working. As a plus I ended up installing Mainsail and learning a fair amount about the inner workings of Klipper. I initially tried to slow down the movement, and tried reducing the area to probe, however that was not successful.
