Not feeding through nozzle
Hi…Newby question. My Ender 3 v2 neo wont feed through nozzle. i can move the extruder and it feeds normally when i remove the nozzle. I am assuming it is just the nozzle clogged? i have removed and cleaned but it just repeats the problem. I presume that nozzles are sometimes just needing to be thrown and replaced.
Is the nozzle heating properly? Could need a new heater or thermistor.
Hi there. Thanks for the reply. Yeah definitely heating, had it at 225. Its like a clog that reoccurs. I can get a bit out, then it stops. inside the nozzle, when cooled it forms the nozzle shape, but not getting out.
I am having the exact same problem. The extruder will move as if it is printing, however no filament comes out of the extruder. We replaced the nozzles, the temperature is correct and it is heating up. What else can it be?
I had this same proplem. Before you buy anything remove the nozzle and the plastic tube and connecter and make sure there isn’t a clog in there. Sometimes the tube and the nozzle don’t seal and filimant will biuld up and clog your extruder.
It could be a bad section of filament. Strip off a meter or two and retry. I hold a removed clogged nozzle with long nose locking pliers, hold a lighter to the nozzle, then push in filament until it either extrudes or let it cool some and pull on the filament to pull out the clog. You should be able to see through the nozzle when it is clear.
