Not functioning correctly
A bit frustrated, my Falcon2 pro has stopped functioning correctly, I use lightburn and up to now only had a couple of minor issues, but now when I try to cut or engrave it won’t even complete a frame, it stops after a couple of inches with a loud beep, I have reinstalled lightburn, removed all cables and tried others but no difference, I am getting this error code if anyone can advise that would be great, thanks in advance
Homing
inquire_info->power:22W ,CV50-LASER-22W-Release V3.0.5 20231129-1001
ok
<Idle|MPos:0.025,0.025,0.000|Bf:127,65535|FS:0,0|WCO:0.000,0.000,0.000>
ok
Starting stream
[MSG:Restoring spindle]
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
On or near line 0:
Stream completed in 0:09
[MSG:Using cpu_map…esp32-s3]
Grbl 1.1f [‘$’ for help]
" After un install and re-install "
Waiting for connection…
Project loaded in 2 milliseconds
usb connect succeed
ok
[VER:1.1f.20220810:]
[OPT:VHL,127,65536]
Target buffer size found
[software versions: CV50-Pro-MASTER-Release V1.0.0 20231129-1024]
ok
Homing
ok
ok
Starting stream
Layer C03
ALARM:3
On or near line 0:
Job halted
Stream completed in 0:01
Ciao, ho il tuo stesso problema da qualche settimana, ho provato a montare il modulo 1,6w e funziona. Secondo me è il modulo che non va, poichè anche mettendolo a 20w funziona per pochissimo e si blocca nuovamente.
Ho contattato il supporto del sito dove l’ho acquistato
That ALARM:3 can be super annoying! Since you’ve already checked the cables, have you looked at the limit switches or the laser head’s path? Sometimes even a tiny bit of debris on the rails or a cable snagging as it moves can trigger a ‘reset’ because the motor feels resistance. Also, check the flame sensor sensitivity in your settings - if it’s too high, the bright light from the laser itself can sometimes trip it and kill the job.
