Official Creality Direct Drive Issues
I purchased the direct drive for my Ender 3 v2 Neo. After installation I noticed the carriage does not hit the limit switch located under the y-axis rail. Anyone have the same issue?
I had this issue but it was on the X axis. I had to relocate the limit switch to position where it would be triggered. I printed new housing for the limit switch but I had to manually trigger the switch in order to print it.
I am having the same issue on the left X axis. It does not hoit the limit switch but it does hit the plastic cover. I can file the cover down so it doesnt hit but I still have the problem with nothing hitting the limit switch. Was the plastic print you used available online?
Thanks
