So…New to the hobby. Was using 6 but kept on getting weird results in temp test where it populated about 50 layers etc. Unistalled v6 and installed latest v5. I now get the following error upon opening or importing a test print. IF i restart it, seems to work the second time. I’ve also installed the lasted nvidia drivers. Any clues or pointers as to what to check thanks ?
Hello Gedc,
Do you have System Restore active on your computer ?
If so, I would restore to before you installed CP version 6.
Cheers.
P.S. I have a program called AOMEI Backupper (free version) on each of my computers.
It is simple to use and extremely worth having. Need to have a drive to back up to, either internal or external.
Cheers.
HI. Checked and restore point was after installed 6 but thanks for the suggestion. Funnily enough the second time i ran it, it worked and now printing the temp test. Will play around and see how to replicate the error. Thanks Ged
