Open source for Ender 3 V3 SE & Nebula Pad
Will the open source information for the Nebula Pad and Ender 3 v3 SE be available?
I’d really like to know this as well
Would like root access on the Ender 3 V3 SE with Nebula Pad.
Will it be available in the next firmware release? @CREALITY
I would also like root access on the Nebula Pad.
Currently I have Nebula Pad on Ender 3 V3 SE.
From software perspective, Creality OS on Nebula Pad shouldn’t be much different from Ender 3 V3 KE, just some diffs in the config files, so it should be kind of easy to officially support root access on Nebula Pad considering that Ender 3 V3 KE already has it.
Thank you
@CREALITY I also would like to have root access on the Nebula Pad. with you giving this now for the K1, why did you not have the Creality Pad setup to give root access? I want the full fluid web interface, not the stripped down version that you use by default.
@CREALITY me gustaría que pudieras colocar la opción de root del nebula pad.
