Orca Slicer & Creality Hi
Hello.
I am starting with the OrcaSlicer software to have all the printers in one place, but I have encountered a problem with the Creality Hi Combo.
Error: The OrcaSlicer software cannot show the printer in the devices panel for remote use. The typical error (404 Not Found) appears.
Extra: It does appear in the Creality software.
Does anyone know how to fix it? - If so, I would appreciate a small tutorial.
Thank you.
Hi.
Fluidd web ui runs on port 4408. If you enter ip and port 4408 in the OrcaSlicer2.3.0 connection configuration you will get the working device panel but Orca will not be able to send the sliced ​​printout to the printer.
By the way, are you having problems with your printer using CrealityPrint v6.1? What slicer do you use?
I also encountered similar problems using OrcaSlicer v2.3.0
Does not help
Hi everyone,
I was having problems with prints in the Creality software, so I started using Orca and had the connectivity issues described.
What I do is slice in orca, export the gcode and then load up the Creality software and load the orca gcode so far no issues works great.
Let me know if it helps.
I think I need to do this because I AM SICK of the Creality CONSTANLY CRASHING :rage:
To access the Klipper firmware on the Ender model, it is necessary to first enable root access. It is presumed that this procedure is also applicable to the ‘Hi’ model, as it uses the same operating system (OS). Consequently, access via Orca Slicer should then also be successful.
just use latest creality print 6.2, and latest firmware .48
