OrcaSlicer 2.4.1 — K2 Pro CFS + Device Control Findings
For anyone running OrcaSlicer 2.4.1 with a K2 Pro, here’s what I’ve found on connection methods and what actually works.
The Setup That Works
  • Host Type: CrealityPrint
  • Printer Agent: CrealityPrint
  • Hostname: 192.168.1.xx:4408 (your printer’s IP + port 4408)
See screenshot below.
What You Get
  • Device control through OrcaSlicer — printer status, temps, print management — all functional
  • CFS filament slots visible and manageable
  • Prints send and run without issue
What You Don’t Get
  • Camera — the K2 Pro uses WebRTC architecture that OrcaSlicer cannot access regardless of connection method. This is a hardware/firmware limitation, not an OrcaSlicer issue.
Background
Prior to 2.4.x the only working OrcaSlicer path was Octo/Klipper at :4408, which gave device control but no CFS sync. The CrealityPrint host type added in 2.4.x adds CFS sync — and using :4408 in the hostname field is what restores device control alongside it.
Camera remains the outstanding limitation. If anyone has found a workaround post below.
I think you need to use Creality Print or the Creality web/mobile interface to view the camera. Creality Print - Creality Slicer Softwares Download
Try http://printer ip_address:8000
