Just pulled my new K1 out of the box, walked through the setup, verified my voltage, turned on the machine, and the LCD is just showing lines (like a bad signal or broken panel). I have no text or buttons on the screen. I even tried reseating the cable (i.e.: bad connection), nothing useful is displaying.
I tried to reseat it a couple of times - even verified if the connection could be inserted incorrectly. Ended up using Facebook Messenger to try to get help from Creality Customer Support - unfortunately its international time zone tag.
Sorry you are having that problem with the screen. Very frustrating especially on a new machine.
Are you able to print anything using the PC to see if anything else is wrong. See if the camera, lights etc is working. Could be a power supply…? Just so you’ll have an idea what to tell Creality.
The unit powers up (fan, light, screen). I haven’t been able to do the software setup yet. Since I can’t select anything I can’t pick a language, join the network, etc. Just to make sure I wasn’t crazy, I don’t see an ethernet port on the K1.
I would take the bottom cover off the machine and check all the connections. Especially the ribbon cable going to the screen… Just to make sure everything is plugged in properly… I wouldn’t know where everything goes but if something is loose then that’s something to fix…
Also make sure the outlet is supplying proper power or try another one. Never know.
