Hey…I am trying to decipher which program is creating the slow movements of my K1C.
I use a CAD program to export parts from it to STL format and CrealityPrint to manage the slicing and printing from my K1C.
I mentioned this issue before today and I want to rehash it.
Cylinders print slowly while cubes print quickly. I set up my printer at 45% infill and 200mm/sec infill speeds.
I cannot print a fastener for some reason quickly while the same settings for cubes print quickly like advertised.
Also, is there a setting for circular rounding or cylinder making at high speeds or regular speeds with the K1C?
travel_short_distance_acceleration is the answer I think for the small perimeters I am encountering while printing.
I can try to see if this works. I will attempt to return service.
travel_short_distance_acceleration is not the cure…blah.
This print is giving me the willies.
slow_down_layer_time is the answer. Thank you and goodnight.
I am wrong again. I am not sure what to pick and when to pick it.
I still cannot configure the PA6-GF well enough to print intricate parts. Does anyone know of the particular build parameters and/or OPTIONS that are needed to make a smooth, bearable print.
My threads on fasteners look like they jumped ship and are swimming to get away…
