Password Error
I just upgraded my router on my network to a TP-LINK Ax4400 now the k1 Max won’t connect it was connecting through my NETGEAR AX4 contacted Creality via email but no response. are any other users haveing the same problem… and is there a fix. beside using a flash drive to put gcode on it…
Thanks
Kim.H
OK everyone i had did some digging and found out after 2 days that if you have a newer router that combines the 5G and the 2.4G you have to separate the channels and not use the smart feature, because the k1 or MAX only use the 2.4G side of the WIFI so you will have to log into, but each WIFI channel have to have a different password, the 3D printer won’t work on the 5G side of your router .
I hope this helps
