Has anybody successfully implemented a pause during a print? I’d like to pause at a certain level to add captive nuts Into a print, i cant seem to find a suitable or reliable way to do this. The cr10 does not seem to support the pause code…any ideas?
Hello @Izzug ![]()
Have you tried it using Creality Print…? Right click shows the “Add Pause” menu.
Yep, i can put the pause in, you can see it in the code, but the CR10 does not action it
Did you ever figure this out? I have the CR010S and I’m trying to do the same thing. I’m going to try different slicers and see if I can see the G code and modify it to some other values.
You might have already done this but make sure to re slice after you put the pause in. ![]()
