I’m new printing PETG (not with PLA) and trying to print with Ender 3 V3 KE I’m not abe to fix the print on bed. I tried different temperatures (230 - 250ºC for extrusor and from 60 to 85ºC for bed), different speeds (20 to 50 mm/s), three slow layers, brim, etc. and alway, after or before, the piece is taking off from bed.
Please, what advice may anyone say to me to print PETG succesfully?
A little closer to the bed on the z offset, though not as close as PLA which likes a real good squish. A properly cleaned bed and IPA too. Gluestick if all else fails, I’m not ashamed to admit to using it sometimes.
printing petg with a textured PEI plate ? if yes then the z offset must be lower, use a thin paper to set the ofset right, the paper must be difficult to move.
I apologize if someone mentioned it already here but PETG really likes to stick to the build plate so once you get your Z offset dialed in use some glue to act as a release agent to make it easier to get the model off the build plate. Kind of like using PAM to get the pancakes out without sticking…
I didn’t mentioned that the problem is wit the V3 KE with texturized bed and with my Ender 3 v1 with mirror bed too using same material.
When adjutst my Ender 3 v1 I use a peper for PLA, I understand that for PETG this offset is higer (I’ve read three pieces of paper but I tell you this doesn’t work, I think is too much).
On ender 3 V3 Ke, how do I adjust Z offset? I go to Adjust on menu and I have Z offset set to -2.18. If I move it the Z axis is too far from bed, I can’t use the paper and whe I print with calibration enabled the value changes and now is -2.20.
