PETG Warping/all problems Tips & Tricks
Hey Guys I created this Topics So we can help Beginners or New users of PETG.
My main problem with PETG when I started was it warped a lot as I had a Non Enclosed Printer / there could be other reasons.
For fixing it I used multiple things which you could try as well and find the best work around.
Adding a Brim :- add a Brim in your objects through the slicer settings it will keep the object away from Warping and will warp itself.
Make your corners rounded :- If you have a object with sharp corners try to make them round so the stress on the part spreads instead of staying on a single point.
Increase the Bed Temperature(Not too much though) :- By doing this the internal stress in the part will become loose and it will probably Warp less.
Use Glue Sticks or some kind of print adhesive :- The Adhesive will keep the Petg sticked to the Plate so less chances of Warping.
Now there’s always room for improvement so you can send more tips down the comment and I’ll try to add them here. Let’s help the Beginners and New Comers.
Some of the informations might not work for everyone and you’ll have to try more things So just keep kn trying and you’ll figure it out. : ) Good Luck.
I have also found slowing down the first layer speed, and adding really big brim (mouse) ears on slimmer sections less than 3mm wide has helped too
I always had issues when I printed TEPG on my Ender3 S1 Pro. I upgraded to a K1c then a K2 combo. Now I have no problems with either printer. allways clean my bed with Isopropyl Alcohol before starting a new print. This applies to my smooth plate on the K1c and the textured plate of the K2. I have only had one instant where the print lifted on the K2 when I did not clean the plate.
Bill
Thanks for adding another solution on this thread :slight_smile:
PETG warps because it gets cooled down faster on a open frame printer and doesn’t get enough time to relax and hence a inward force pulls it and lifts off the part off the build plate. And a enclosed printer helps in fixing that. I am happy for your new printer hope You print good stuff :slight_smile:
