Ok I have a two color print. I have run the PA and Flow rate for both(Inland Pla .028 and 99%, Creality Hyper Pla .044 at 100% found through fluid). I have the filaments setup in Creality print and sliced with the correct setting for each. BUT while running the file on the printer it only uses the PA of .028 for both Filaments. The print itself looks ok but the the joints between the two filaments are puckered or dented. Any thoughts?
Thanks in advance
Steve
Hey @Steve_Bertsch, I hope you are doing well! If you haven’t resolved this problem, here’s a potential cause. I saw you have created custom filament profiles through Creality Print! NICE!
After loading the filament rolls in the CFS - from the control panel screen on the K2 itself, what filament profiles are selected for the rolls you are printing with? Are they the custom ones you made within Creality Print, or are they Generic PLA + Creality Hyper PLA?
I altered the filaments in creality print and then sliced it with those settings.I would think the gcode should override the cfs base settings.
Thanks
Steve
