It seems to me a tf card read problem could do this.
Get some electrical contact cleaner. SAFE FOR PLASTICS. I like MG Chemicals brand. Electrosolve. Shoot it into the card slot while powered off. Clean the contacts of the card too. It evaporates very fast. Good ventilation, no sparks or flame!!!
Copy all the files off the tf card. Reformat the card. I think you need to do FAT32 format. Do the full format, not fast format. Copy the files back.
I think you can also download the Ender 3 card files from Creality site.
Maybe this will help.
I have noticed in some of my exploring, references to printing via USB port.
Cura seems able to send a file direct to a printer that is hooked to your PC via USB? I am going to try this out at some point. But maybe you should stick with the regular for now. I am not an expert in this by any measure.
Turn off power saving on your windows pc otherwise the print will stop while using usb. If you have an old laptop, pc or sbc sitting around install Linux on it and install octoprint then you can send files from the slicer to it and that acts like your card and prints for you. Plus it has many other good uses.
Basically it looks like your sd card reader is dirty or damaged and while it’s printing it’s disconnecting. Causing the print to finish as it reads line by line.
I’ve tried different SD’s and formatting methods, no change.
Tried taping the 5v pin, no help.
Giving up anyway, getting a 3v2 neo and 4.2.7 board for the Ender-3.
Thanks for your help,
