Print issue with TPU
Hi more TPU questions. Printing with TPU at 235degs 30mm/s with retraction reduced length but tried with retraction off. Does about half the first layer (150x150 square) then stops feed though the extruder. Head aaand extruder have been cleaned. Filament is sealed butvis running outside in the air.
Any ideas would be great. Very new to this
где катушка стоит? если сбоку то распечатай крепление на верх и возьми маленький отрезок ptfe трубки около 5-6 см вставь его и в него тпу и затем пробуй. Но как по мне лучше заменить экструдер, этот почему-то очень плохо тянет тпу даже от креалити
Plus 1 for top spool mount, after I printed a top spool mount (and relocated runout sensor) I have been printing TPU with a lot less errors…
Use the 0.4 special filament profile, if you see issues on the first layer just manually add 5% flow via the expert settings and it usually comes right
