Hey all! I can really use some help. I’m having an issue with printing a Ghost from Destiny (https://www.printables.com/model/460159-destiny-ghost). The center of the print needs supports which I’m using normal. Once the supports are done the actual print walls won’t adhere correctly and start to curl on the first few passes. Here are some pics of the print results and settings. Got a V2 w/ direct drive, pei sheet, and yellow springs. I’ve leveled and readjusted my -z offset after changing my nozzle (this was after my 3rd attempt at printing and no change after that) I’m ripping my hair out trying to figure this out and I’m not sure what I’m doing wrong. Thank you in advance to any advice you guys and gals can give!
