Hello, the K1C printer is specialized for printing filament with carbon fibers. In the Creality slicer couldn’t find a profile for PETG-CF. Which settings are good to start with for Bambu Petg-CF? Is normal PETG good?
Would be good if Creality could provide an own PETG-CF filament and a profile in the Creality Slicer.
yes creality print 5.0 has that
look at these possibilities it has
look under material and search for Generic PETG CF
on this picture i selected generic petg but in your case you can select genric petg cf
Yes that would be good. Downloaded Creality print 5 for Mac (v14.0). But on launch it crashes “The software closes abnormally,whether to open saved temporary file?”
Is there a cxprofile to download for Creality print 4?
Launched again, now it’s ther
For Bed type, which is the “Plate B - For Carbon”, is this textured PEI Plate?
Anyone tested Bambu PETG-CF with Creality print 5? Are settings good?
yes these are good settings
open it again and it will work
answer
Yes it is for a textured B plate
Anyone looking for settings for PETG-CF Bambu, these are working for me:
solution-to-printing-bambu-petg-cf
The Change Z offset I didn’t add.
In this profile speed is 300mm/s but on Bambu Petg-CF filament is <=200mm/s recommended, so changed values like from the post above
Hi, I just ordered a K1c with Creality pteg. Do you need a carbon build plate to print this?
I would put a good layer of glue on your smooth PEI and print away. PETG/PLA on my smooth plate stick too well so I use the glue as a release agent
I think a K1C might even come with a textured PEI plate, if not, I would order one if I was you.
You get a perfect littlebit textured surface with the textured PEI plate.
And it will come loose easy when cooled off.
