Print placement
Hi, newbie here, none of my prints start in the middle of the base plate is this an issue, (sometimes I know it is as it tries to print off the plate) is there an easy way to start the print in the middle of the base plate? I presume whoever made the print used a different machine to mine hence coordinates differ. Just a guess. Any comments welcome, loads of prints don’t stick to bed for some reason.
Do you have the correct bed size in your slicer? I know I have accidentally sliced Ender 5 plus files and sent then to the V3SE, funnily enough it doesn’t fit.
Are you using Creality Print 5.xxx…?
If you use a .3mf file I believe it contains a profile for a certain printer and it probably won’t work or center the same as yours.
Try using .stl files instead.
Also like @Bonfireman stated…Make sure you are using the correct printer profile…
