I am trying to print the below item and for the size (length of filament) the print time seems way way to long, almost doubled what I think it should be.
Here is a pic of my settings.
Thank you so much for any help.
Change your setting so you can see all options. Expert or advanced i believe. Go to your speed. Probably your small perimeter is set to about 20mm/s usually this is slower due to accuracy on small parts you can increase the speed or adjust what perimeter is defined as small. Hope this helps
Thank you, My print speed is as fallows
print speed 60 mm/s
Initial Layer pseed 25 mm/s
Initial layer travel speed 125 mm/s
