I want to print a part, half of it printed with 0.1 mm layer height and the rest half with 0.2 mm layer height.
I have Ender 3-V3 plus and I use Creality slicer.
Any ideas if this possible and how?
You could investigate adaptive layers
There are two methods, the first one is to use modeling software such as Blender or Tinkercad to divide the model into two parts, one set to a 0.1mm layer height and the other set to a 0.2mm layer height, and then slice and save them as two independent G-code files. If you don’t want to do cutting processing, perhaps you can manually edit the G-code, slice the two parts of the model separately in Creality Slicer, and then merge the two G-code files to ensure that the 0.1mm layer high part is in the front and the 0.2mm layer high part is in the back.
