That is a broken thermistor, you will need a replacement. The 5 plus thermistor are very long wired beasts, either cut and splice a standard thermistor into the existing loom or go to Aliexpress and get a whole new loom, bonus of new fans, heaters and everything, I think my last one was £15 for the whole thing compared to about a fiver for just a thermistor. Keep a spare these things break really easily.
Thanks for that. Do you have any link to share please? For both the standard thermistor and a whole new loom. Many thanks.
New loom. and Thermistor actually that is the longer thermistor, I keep a couple of spares just in case as they are so easy to break.
Its the correct sensor but too short, try this one it is nearly twice the length or make up an extension cable.
Hi all,
I just replaced mine with Microswiss. For some reasons, filament is not coming out of the nozzle. Any ideas please?
Cheers.
Amir
Push the filament in as far as it will go then press the lever and push it in a little further, should be all good to go
Thanks Gary. Very much appreciated. Prints perfectly.
