Prints failing or getting huge cracks during print
Currently I’m printing some terrain for a dungeons and dragons tabletop game.
The last print had the same issue I occasionally had with the previous prints.
More than half of the printed parts simply fail after about 20%, while others on the print bed develop a large crack, and others are successful. Failed parts have cured resin remained on the FEP.
All printed parts should be the same height in the end.
I’m using the Lycher slicer and added the settings as image. I use the Elegoo ABS filament-like 2.0 resin.
I hope you can help me …
I believe you need a printer with an enclosure and heated chamber for ABS.
Edit:
Ok… I guess you are using a resin printer… ?
Which Resin printer are you using so I can move this topic to the correct section…?
This is the section for Ender-3 V3 Printers…
Sorry, I sent the wrong section. I am using the CR-10 Smart printer
