Pro or Plus?
I’ve written previously on the K2 form about moving from an Ender3V3 KE to a K2. I’m now torn between a Pro or Plus. I mainly design and print structural parts and I like the idea of the additional build plate size.
The only thing putting me off the plus is the horror stories of them being unreliable or needing constant settings tweaking. I really don’t want to be bothered having to dial in for specific prints ( more so than design for build) .What is everybody’s take on the K2 plus, is it reliable or finicky?
Happy Easter all!
Surely, when you decided to buy into the Creality ecosystem, you knew this was a tinkerer’s machine. With my K2 Plus, between fouled nozzles, broken extruder covers, and having to MacGyver fixes for mechanical design flaws that never should have made it out the door, this is anything but a set-and-forget printer.
I have spent over $200 on replacement parts and add-ons, plus countless hours trying to force this machine into a level of reliability it should have had from day one. Regular intervention is not the exception with the K2 - it is part of the ownership experience. The AI fault detection is nowhere near ready for prime time, and that becomes even more obvious once you move away from the factory 0.4mm nozzle.
In my experience, Creality pushed this design out before it was properly matured. On long prints, stand-alone operation is risky, and you should expect to check in periodically unless you enjoy discovering failed prints and blobs of death after the fact.
If you want something more appliance-like, and you are willing to surrender access to the guts of your own machine, then Bambu is the better option. But Bambu’s philosophy is clear: if the feature is not there, then apparently you did not need it, because they know better than the customer. Stay inside their approved little box of use cases and things generally work fine. Just do not expect much patience for anyone who wants to push performance, customize deeply, or operate outside the limits of their ecosystem.
I own both Bambu and Creality machines, and neither company deserves brand loyalty. Creality gives you openness, but too often that openness is really just an invitation to finish debugging the machine they shipped. Bambu gives you a smoother experience, but only inside a locked box where customer freedom comes second to their business model. So pick your poison: Creality sells you a workshop project, and Bambu sells you a polished cage.
Thanks for the pov. I’m not looking to take on a project, printing is about parts to me not about the printing IYSWIM.
My ender 3 has been absolutely solid for me - so I was looking for this in K2. Perhaps I should look to bambu instead. I’ll have a look what’s in their range.
Many thanks
To answer your question about the K2 Plus, it’s a bit of a roll of the dice whether you’ll get one that’s reliable without needing to constantly work on it. My K2 Pro has been pretty reliable so far as a hobby machine. I’d like to get a K2 Plus because of the larger build plate but like you I wonder what kind of issues it will come with. As with any machine, you’ll still need to tweak your slicer settings a bit depending on the print and the strength you’re aiming for.
A couple thoughts:
1.) I would buy from Amazon or a place that has a good return policy.
2.) See step one.
Keep us updated on what you end up doing. :+1:
Many thanks,
I’m content using brim settings, support settings, temperature etc. Ideally id not like to have to keep messing with z offsets and general tweaking due to odd behaviour! I think I’ve been lucky with my ender 3 as it’s been so good.
I hadn’t thought of buying through a reseller.
Kind Regards
Then we have that use case in common. My primary use for a printer is parts fabrication, either from CAD models I create myself or from designs I have to modify. Fast iteration and material flexibility were major reasons I chose the K2 Plus.
Calling the K2 Plus a disappointment may be slightly overstating it, but not by much. It has been able to print materials like nylon, but not on the standard Creality build surfaces. To make that work, I had to go outside the Creality ecosystem and source a third-party Garolite/G10 plate. That is exactly the kind of thing that makes me miss the broader range of mature accessory options in the Bambu ecosystem.
One major concern I have with the K2 Plus is the very limited CFS, which cannot support some of the same support filaments, such as PVB, that Bambu’s AMS handles without issue. That is a significant limitation.
If there is a real answer to that gap, it certainly is not something as expensive as the Prusa XL, and it is not the near-vaporware Snapmaker U1 either. The U1 may hold promise, but it is still in the science-project phase. For me, a product is not complete until it can be ordered through a major retail channel and spare parts and accessories are readily available.
Snapmaker says it will be out of that phase in five more days, on 04/10/26. For me, the ultimate concept is a true multi-material, multi-nozzle printer. I want the ability to print prototype layers with a 0.8mm nozzle, switch to a 0.4mm nozzle for finer detail, and use dedicated support filament without wasting so much material in the process.
I am far more interested in hearing from real customers who have owned it for six months than from fanboys who got early access and are emotionally invested in defending it after backing it during the Kickstarter phase. The real litmus test is what ordinary buyers say after purchasing it as a finished product. In my view, those opinions are far more reliable.
I’ve only owned my K2 plus for coming up on 80 days. I do however have almost 500hours on it during that time. It has required less maintenance than my kitchen kettle to use a metaphor I see here way too often. It’s a solid machine, with a large build plate and is more than capable of printing with only routine and regular maintenance as you would give any other piece of equipment in production.
Hi,
I’ve just noticed that the creality K2 doesn’t support TPU!
I assume because of the feed system. TPU is a common material for me - in fact I had wanted to experiment with transitioning between TPU and PETG for mounts and bump stops.
I’m leaning towards a Banmbu H2, possibly with a laser cutter built in. I’m just checking for bambustudio Linux support. If I like studio I think that’s the way I’ll jump.
The H2 will print TPU but not with the AMS so it’s not a perfect solution - but the laser cutter extension is an interesting addition!
Hi everyone,
Is the Plus still worth it? According to the specs the pro has several hardware improvements compared to the plus.
Are there already newly produced Pluses with upgraded hardware and if yes do these upgrades fix the bed leveling problems. (and how would you know the needed revision)
Maybe the main question is, aside from the larger build volume, would you buy the pro or plus?
Cheers
Ben
i recommend you checking out aurora tech’s reviews, as she has reviewed both the k2 plus and the k2 pro - https://www.youtube.com/@AuroraTech
i don’t have a k2 pro, so can’t comment from experience, but i do have the k2 plus, and it’s overall a good machine
Actually, that is not entirely the case. It is true, the CFS does not support TPU. However, using the external spool does work. I have used the external feed on both 95 and the much softer 90A using the external spool option without incident.
That’s good to know on the TPU front. I wasn’t sure if I wanted the CFS and the more I hear about it the less I think I will use it.
I downloaded Bambustudio last evening and was surprised that it supported the Ender3 v3 KE in it’s default. It looks as though it’s based on cura so very similar to the creality slicer. It seems to offer everything I want.
I’m really torn now between an H2 variant and an X2. The thought of buying a much more capable machine and having to fight with it to get the same level of reliability as the ender is putting me off the X2. True multi tool head operation may be promising.
I’ve also had a look at the Prussa L and XL but again I’m reading mixed reviews on reliability, also the hot end is only running up to 290, ok for the materials I use now but could be a problem later.
I will eventually take the plunge :slight_smile:
My K2 Pro is a workhorse. I don’t agree with @JoeFriday - I wouldn’t call any of my 14 Creality printers as “tinkerer” machines, not even my OG Ender 3. My printers are almost entirely stock and the only issues are routine maintenance like unclogging a nozzle or extruder. And I run 10 of them pretty much 24/7 for my business (my older ones are mostly retired now). All are reliable with very few failures. I turn off the AI detection stuff personally as I have found I don’t need it. I start them, check the first layer, and let them do their thing. It’s always detected things like filament runout or jams and paused with no issues - even had my K2 Pro tell me there was a problem with a pfte tube the other day when it actually split.
As far as your original question - both the Pro and the Plus are great printers. I went with the Pro because of how much heavier the Plus is and I couldn’t handle moving it myself (63 yo woman). The Pro is heavy, but manageable for me. And 300x300 is my sweet spot for build volume since I need it for most of my products (I have 4 E3V3Plus printers for the same reason). But if you can handle the extra weight and size, I would probably go with the Plus for that extra build volume.
Use Case Is the Issue
It does not matter whether someone owns one printer or one hundred. Printer count does not answer the point I made. The real issue is use case.
What the Original Poster Actually Asked
The original poster was not asking whether the K2 platform can print basic parts successfully in a production environment. He said he mainly designs and prints structural parts, is considering moving up from an Ender 3 V3 KE to a K2 Pro or Plus, likes the additional build volume, and is specifically concerned about reports that the Plus can be unreliable or require constant settings tweaking. He explicitly said he does not want to be bothered with having to dial in specific prints beyond normal design-for-build considerations.
That is exactly the context I was responding to. I was not making some universal claim that no Creality printer can produce acceptable output. I was offering guidance to someone whose stated use case overlaps with my own and whose concern was whether the K2 Plus becomes finicky when pushed beyond easy, forgiving jobs.
Why Some Printers Only Seem Reliable
A machine can appear reliable when it is kept inside a narrow operating envelope - routine materials, routine tolerances, and low-demand parts. Under those conditions, many modern printers will seem dependable. The real test is what happens when you push the machine into the capabilities it was specifically advertised and promoted to handle.
That is where my criticism of the K2 platform comes from.
If your work is mostly basic production of decorative items, simple parts, or other low-demand prints, then yes, the machine may appear perfectly fine. But that does not disprove my point, because my point was never about light-duty printing. My point was about how the printer behaves when used for the more demanding engineering-oriented applications Creality used to market it.
Where the K2 Platform Falls Short
Here are several examples where the machine falls short:
  1. High-temperature filaments
    Printing higher-temperature materials often requires extensive tuning before results become acceptable. That directly undercuts the marketing around active chamber temperature control and the implication that the platform was designed to support those materials competently out of the box.
  2. Use of factory-supported nozzle options
    Try using a 0.2 mm nozzle. The poop chute design is inadequate for that configuration. The filament curl produced during purging is too lightweight and gets quickly caught in the chute during filament swaps, instead of clearing it properly. By comparison, Bambu’s similar chute design is notably taller, which reduces that failure mode. On the K2 platform, this looks like a preventable design oversight that should have been caught in testing.
  3. Nozzle changes
    The nozzle change process is too clumsy. I have broken too many nozzles during removal, with no practical repair path afterward other than full hotend replacement. For a machine positioned as capable and versatile, that service process is poorly executed.
  4. Extruder pneumatic cover design
    If someone never has to service the PTFE tube, they may never notice the issue. But early-life clogs and PTFE tube removal are not unusual. The pneumatic connector should have been designed as a removable, serviceable component. Instead, it is molded into the plastic cover necessitating a complete replacement when the connector eventually fails. That is a simple mechanical design flaw that could have been avoided.
Why That Reply Does Not Refute My Point
So no, my criticism is not disproved by someone saying they run a farm of mostly stock machines without issue. That only shows the printer may perform adequately for their use case. It does not answer the question the original poster actually asked, and it does not invalidate the experience of users who are evaluating the machine for larger structural parts, engineering materials, broader nozzle support, and the kinds of operating conditions Creality itself used to promote the platform.
My Point Stands
My comments were directed at that buyer, in that context, based on that use case. That is the standard by which I judged the machine, and I stand by it.
@Patrick1234 I was reminded by @JoeFriday’s post that I have actually been pretty successful using my K2 Pro to print with ASA because of it’s UV properties and strength using the default settings on Creality Print. I did have to change some fan speed settings and one clog but after 10 rolls I’ve not had any problems with it.
Many thanks everyone. I’m less sure than ever which way to jump - though it has made me look winder than I had done so. My worry is going from a printer that I very rarely have issues with to one that constantly is unreliable and fidley. Perhaps I should have less doubt of the X2.
I have the K2 Plus. I Have had very few issues with it. One issue was trying to print a second print, whether form the printer or from the computer. It turned out the ORKA slicer was the problem, not the printer. I switched back to the Creality slicer and it works every time. Print hundreds of prints, some of them up to 36 hours of continuous printing, full size head busts. The only problem I’ve had is customer support. You can’t talk to a human and the emails you receive look like a bot answered you with little help.
This is exceptional advice. If you get a good one, you are good to go, but if it isn’t right out of the box, get out of it immediately. The “parts” road you will have to go down will not be worth it.
I have 3 K2 Plus machines, and to be fair, a couple Bambu. I personally feel more confident in Bambu. I have experienced a myriad of problems with one of my K2 Plus machines that I believe to be unfixable. It was, and still is, an absolute lemon. The other 2 K2 Plus have been mostly fine, and for parts, brackets, and relatively simple prints, they are good. Just as other users have stated, I would not trust a complex print to a K2 if I am not within earshot of it. They do not instill total confidence, and sometimes make me feel like I must be messing something up in the settings before printing. The quality control between the 3 K2 Plus is also incredibly confusing. Not one of them is the same as the next. I have purchased several replacement parts for one, specifically throwing anything at the wall I could to get it to print correctly, while noticing that the parts don’t match the other 2 machines. My 2 cents would be that if you decide to go with a K2, the plus is worth the difference, but do not linger if it is not working well out of the box. Send it back immediately; do not wait for support to help you “work it out”. Creality support has been good to me, but my experience has shown me that a machine that is off to start, never gets “right”. There are ones to be had that just work right for whatever reason, and some just don’t.
Hi,
I’m failing to find out what the creality returns policy is from the web site.
Has anyone managed to return a lemon? Is it best to buy direct or through Amazon?
I think that if I am confident I can return it I’ll go to X2, if not I’m going to jump to one the Banbu H2 varieties.
