Problems after K1C CFS upgrade
hello
after a long wait I managed to upgrade to K1C with CFS, but they came with some problems.
  1. when I print with a single color it doesn’t do the purge tower, and the first cm (5…10 cm path) to print are not done correctly, it doesn’t have continuous printing.
    the printer also does something incorrect… when printing starts it heats the nozzle to the set temperature then does the purge stroke on the left side (without feeding the extruder with filament) then it realizes that it has no filament and moves the extruder to the “poop” area pulls filament from CFS it feeds and then starts printing with small problems at the first CM of printing
    how can I move the purge stage on the left side to be done after feeding the extruder with filament.
  2. I tried to print with Creality CR-TPU filament (which I printed without problems before the upgrade) directly fed to the extruder without the Teflon tube but I can’t anymore, I can hear from the extruder how when the extruder is working, the toothed wheels slip on the filament and break it in the extruder and to fix it, the entire extruder must be dismantled with all the 2 cables, 1 hour of work time
