I recently loaded the latest firmware for my Sonic Pad, V1.0.6.54.20, to find I am no longer able to print from a USB stick. When I went to copy from the USB to the local drive an error message “File Copy Failed” came up.
I tried reinstalling the previous version of firmware via USB but this process failed.
Has anyone else had this experience.
I have the exact same problem and this is the first post I’ve seen about it.
I found a partial solution: save the file in the same way on the USB, but you will need to print it through the application on the creality cloud phone, print from usb and everything starts
Having the same issue now. Tried renaming it to a single letter still no go. Also tried copying it to local will not go. When the cloud software and USB says not available. Any suggestions that you found?
I have had a reply from the Creality R&D team they suggested removing any spaces or special characters from the file name which seemed to solve my problem.
Yes its worked for me ,i have faced same issue .but resolved once i re-named with no special char , Caps and Numeric.
Hi! So what should I do to make the files start printing normally?
What’s the issue your having
Having same issue. Just did the download recently and usb printing has stopped all together. All the fixes I have found wont work so far. Been trying to revert software to with no luck yet either
I had this exact same V1.0.6.54.20 USB-stick bug (code: key86) — here is everything I tried and what happened:
Since there is no “Downgrade” button on the Sonic Pad touchscreen, I started out by re-flashing Creality’s official factory recovery image using PhoenixSuit on a Windows PC to wipe the internal storage and step back from V1.0.6.54.20. Here is the exact process I followed:
Back up your
printer.cfgfirst (open your Sonic Pad’s IP address in a web browser →{...}Configuration → downloadprinter.cfg), becausePhoenixSuitwipes all saved bed meshes and settings. -
Download Creality’s official recovery image (
t800-sonic_lcd_uart0-1.0.6.43.51.img) andPhoenixSuitfrom Creality’s official GitHub (CrealityOfficial/Creality_Sonic_Pad_Firmware). -
With the Sonic Pad powered OFF, plug a USB-A to USB-A cable from your PC into the Sonic Pad’s
CAMport, hold the recessedFELpinhole with a paperclip, and power it on (screen stays black, side light comes on). -
Point Windows Device Manager (
Unknown device→ Update driver → Browse my computer) to thePhoenixSuit_Windows_V1.10folder so it installs theVID_1f3a_PID_efe8driver. -
Load
t800-sonic_lcd_uart0-1.0.6.43.51.imginPhoenixSuit, clickYes(Mandatory Format Upgrade), and wait ~3 minutes until it hits100%and reboots. -
Run the Wi-Fi System upgrade once to land on
V1.0.6.52.92.
What happened on V1.0.6.52.92 vs. updating back to V1.0.6.54.20:
On
V1.0.6.52.92: My USB-stick files printed cleanly right from the touchscreen again! However, I could not get the Sonic Pad to add/link to my phone in the Creality Cloud appon that older version (so I couldn’t print locally or remotely through the phone app), it popped up a harmless error message at the end of every print, and one of my test prints had a small single-layer crack in it. -
After updating again to
V1.0.6.54.20: I went ahead and updated back to.20to see if a fresh install would fix everything—my Sonic Pad immediately showed back up in the Creality Cloud phone app, but the exact same USB-stickcode: key86bug came right back, putting me right back where I started.
This confirms 100% that the bug is inside Creality’s V1.0.6.54.20 update itself—so if you downgrade with PhoenixSuit, stop at V1.0.6.52.92 and do NOT install .20 if you want touchscreen USB printing to work (just know you’ll lose Creality Cloud phone app pairing until Creality releases a patched update).
