I have a K1Max and I have problems with the printing of the first layer when it comes to multiple objects, this does not happen when they are larger prints. I use OrcaSlicer
looks like the z-offset is a little high and also I can see fingerprints so that bed needs a good cleaning, filament doesn’t like sticking to skin oils.
Hello, thank you for answering. The problem is that the filament is totally obstructed… the printer has less than 1 month of use
So the nozzle is getting clogged, if the nozzle is too high that can happen. You should be able to unclog the nozzle, plenty of youtube videos for that. Or try a new nozzle, all comes with the 3D printing experience. My original comments still stand for clean build plate and z-offset.
The offset in z is at 0
Which to me means it needs some adjusting, it is too high, even at zero, I reckon it should be -0.1 or more.
Hello: First clean the bed well with alcohol, then do a new leveling, and if it continues printing that way, you will have to correct the Z-Offset.
Bye
