Purge location misalignment after collision on K1 Max + CFS
Hi,
I have a K1 Max and since yesterday I have the CFS installed, it printed correct and the purge location was set to the hopper location and was properly aligned. It worked fine but then I was reaching into the printer to remove a piece of filament on the bed and of course in that moment the printhead had to move from one corner to the other and hit my hand. The entire print was off and I had to abort. I think I also hear that the belt was jumping some pins so I stopped all and started over with first setting the purge location and then recalibrating the printer but still now when I print it probes the bed level then when it heats up nozzle to 230 degrees it goes to the purge location BUT only the X axis is correct the Y is off it stands right infront of the hopper and purges on the bed.
I moved the head manually to the purge hopper as the system was refusing to go so far so I thought that like this the belt jumped back into it’s right position as I then was able to align it again but still after starting a new print it does the same again.
I’m pretty lost now and can’t use the printer at all. Could please somebody who is experienced help me with this?
Thank you
Frank
I managed to fix it on my own. I downgraded the firmware and upgraded back to the latest then it worked
