So I just got a set of new silicon mounts and I see 3 of 4 are 18mm height and one is 16mm height.
I think the set comes like this, with one mount smaller, to compensate the most deformed side in your printing bed.
So I installed them, and used the smallest in the corner I have more deformation, and I realize I will need to use washers to get them properly level. First install I use them without washers and the adjustment wheel was too loose.
I used a couple washers and finished with 3 washers of 1mm. I basically ended with the same height as the other 3 supports (18mm height). I am gonna check and try a print with this configuration.
I read that it is recommended to have your bed mesh closer to Zero.
Here my mesh data for comparison with the original springs, with 1 washer in the smaller column and with 2 washer in the same one.
My question is… Is this expected? To use washers in the smallest silicon mount? Am I using this upgrade correctly? What do you think about the mesh data I have.
I still making tests with both configurations.
