Read .gco file from sd card
Hello
I am using octoprint to send files to be printed from the sd card. This generates a file that is .gco and not .gcode like the printer wants. the reason why I am doing this way is 2 fold. The printer is fully enclosed and the base is under the enclosure. The SD card is in a tight area (may just get an extension cable if that’s the only route) 2 is this thing needs a z adjustment as the print starts as is consistently inconsistent. I eyeball it as it purges and as it outlines the parts. It’s easy to see and adjust in the printers screen. Printing off of USB does not allow adjustments
So is there firmware that will allow this or can I edit the aurduino config to display the.gco file that is on the SD card?
It’s a cr10s pro with firmware 1.60.3
Thanks
