How to change the filament for the first layer only. To change the plastic only once. If I use the palette tool and just “paint” the bottom layer, then there are several layers inside the model that use two types of plastic at once.
You can do that in the preview Tab of CP6 or Orca slicer, You move the upper layer slider down to layer 2 and right-click on it to select change filament and select the other color whichn you want to use from layer 2 onwards!
You just need to slice the print now again and you will see the result.
Thank you very much, yes, that helped me. I’m printing with PP, polypropylene, and it doesn’t stick to the bed at all. But when I use PLA for the first layer, everything works. If there are other ways to change the filament depending on the specific type of construction, substrate, or supports, for example, I would be glad to hear your advice.
