Recommended print settings for crealityprint using a creality ender 3 v3 ke
Hi,
Im a beginner 3d printer user. Im really struggling to get any decent prints using my creality ender 3 v3 ke, and creality print.
All my prints have very obvious layer lines.
I assumed it wasnt possible to print layer lines smaller than 0.2 with a 4mm nozzle, but I read a post where someone said they printed 0.08 height layers with a 4mm nozzle. Whenever I try to shrink the layer height the print always fails. Does anyone know what I may be doing wrong?
Also, whenever I try to use tree supports the print always fails too. Its like the tree support layer lines are larger than the actual print lines as the print head ends up hitting something ( I assume the tree supports as the same print works with normal supports) and pushes things out of alignment causing the print to fail.
Any advice would be really appreciated - but please make it as basic as possible as im still learning how to do things.
Any screenshots of your settings would be a real help too.
Thank you!
