Reducing poop waste firmware implementation
Hi,
I was watching some videos last night, and I would like to know if there are any solutions to reduce the printer waste when using multi-color printing.
Ideas:
  • Retract before cut
  • Use supports to flush the filament
Regards,
FearL0rd
From the little I know, change can go into infill, but there needs to be enough infill to use it up, retraction before cut is risky for clogs. Still waiting to try all this, delivery due in next 10 days if Creality true to their revised promises!
I had a two color print with use supports to flush the filament enabled. There is an option in the creality slicer.
But, I printed black and white, with two walls. You can see black tough the white walls. The opposite way would be no problem.
