New to the K1 series and I have purchased second hand K1 Speedy. When I tell machine to retract from the screen to change the material it will extrude for like 5 seconds then retract. Is this normal and if so is there a way to reduce the amount of extrude before the retraction?
This is a new development I noticed after the last firmware update. When you ask it to retract, it does the same amount of extrusion it used to do when selecting extrusion. When you ask it to extrude, it does a lot less extruding than it used to. I’m sure we will hear it is a feature.
I also observed the same change in behavior with the last update. I believe we can change it by altering the start-up code but I’m reluctant to mess with if for the moment.
After receiving my K1 Max, the first thing I did was updating the firmware to te latest version: V1.3.3.46
I wanted to change material so I choose for retract in the menu of the printer… It confused me that it starter extruding material and didn’t even retract one milimeter. Not the way to change material, don’t want to jank the material out of the hotend…
At work we have a also a K1 Max, can take the material out with having to heat the nozzle or using the retract option… with my K1 Max it is inpossible, have to heat the nozzle and choose for retract and when it is extruding jank out the filament (yes I do unlock the extruder)…
