As will become painfully obvious, I am new to Creality - used to have a Makerbot Replicator 2 I got cheap from an auction, but that just worked, and I only did PLA printing, so I didn’t really learn as much from that as I might. It got stolen in a burglary and I haven’t had the money to replace it.
A couple of weeks ago I bought a V3 Plus with a stated hot end fault. Was a reasonable price. Clearly the issue was misdescribed by the seller. I have checked the hot-end and it seems fine - nozzle heats if I power it off the printer and the thermistor resistance varies as you’d expect with temperature.
During self-test I get an error with the nozzle. OK just repeats the process witrh the same error “Abnormal nozzle…..”
If I keep pressing “Back” when I arrive at the network choosing screen I see a message “Error 2001, Unknown exception”
I tried the skip-self-test file in a USB key. Bed and nozzle temps show zero - selecting a temperature has no effect, motors are off. I don’t know if I should be able to switch them on or not, but I can’t, and obviously with motors off I can’t move the head/bed. None of the fans except the bottom one and the one that’s internal to the power supply are moving. LED in the print head blinks a couple of times when self-test is running, then stays on. If I connect to the IP address of the printer I get a warning that Klipper hasn’t started.
#1 problem is I don’t know if this has ever worked - seller was clearly economical with the truth. The motherboard has been changed, there was an old one in the box (clearly unservicable, won’t connect to PC) with an opened but full roll of Creality PETG and the toolkit minus cutters, there is no old filament in the nozzle, no marks on the nozzle, only a tiny barely visible marking on the build plate.
I have removed the connections from the motherboard, reflashed the board, installed latest firmware, checked and reconnected every wiring connector, used a PWM power source to check hot end heats (it does) and thermistor works (it does). Checked all the fans. Tested the power supply on and off-load, checked for excessive ripple and poor regulation under varying load - it’s fine. There’s a small daughter board beside the motherboard with four connectors on, two of which are used, but I can’t find it anywhere online to know it’s connected correctly.
So, should I just replace the two PBA on the print head? I can check the wiring harnesses pin-to-pin but is there a diagram I can use to check the pinouts on them are correct? Only one I have just shows the connectors. Is there a diagnostic screen or a way to get better info from the printer that’ll help me debug it? Info on the V3 plus seems scant on the web, or lost in the noise of the more common variants. I don’t really want to be swapping boards blindly, especially if there’s a wiring fault that causes a failure. Are there pins I can check with a scope or multimeter against “correct” values?
Any help appreciated, and apologies in advance if I’ve missed something frustratingly obvious.
