This is the process that I found works.
There is one setting in the slicer printer configuration. Its hard to find but at the top left of the main screen it says Printer. Immediately under this header is the printer. Just to the right side of the selected printer is a pen on a slight angle. When you click this it opens up the User presets menu. 6 lines down is the Z offset. Mine is set at +0.08. This setting overides all other Z settings. No matter if you use the Expert menu on the printer. That has no effect on the Z Offset. So how do you ensure you have the correct Z. By trial and error. Print a small object. Just a 10 x 10 x 10 mm block would do Just print one layer then quit. Start with a lage z positive like 1 mm. Keep reducing this by 0.1 mm until you have the first print layer about a paper thickness on the bed. Slide your finger over the printed filament and you should feel a deginite ridge. Be very careful if you need to use a negative Z. Easy to scrape the bed plate.
Now when you print use the same printer in the slicer in my case it is “Creality Ender 3 S1 Plus 0.4 nozzle Copy (1)”, Copy one because I saved the file after resetting the Z offset.
