Hi! i updated the slicer to V6.2.2.3203 and noted that the printing time for my .3mf files changed even though they are the same. For some reason, the time is now less, showing that it is speeding up which causes problems with the prints.
I confirmed the problem by downgrading again the slicer and getting the usual time and velocity back.
Did someone experienced the same problem?
I even have Device tab empty!! So you have better situation.
I also fin dout that all line width settings in Quality section all are ZERO! Not sure whats going on.
I did this struggles (not worked!):
1- I changed to old versions like: 6.0.3.1591 or 6.2.0.2827. Not works.
2- changed app language! (read somewhere)
3- Uninstalled last installed software to prevent kind of interrupts.
4- Try to add new printer in Prepare tab and Printer window.
5- Restart Rooter, Printer and changing Rooter pass!
I’ve been experiencing problems with print speed after upgrading to version 6.3.0.3420. My print times increased significantly without any changes to settings or material profiles. Multiple G-code files print time increased 2 times and more.
I had to roll back to the previous version. My printer is an Ender-3 V3 SE. I uninstalled the latest (6.3.0.3420), performed a clean install of 6.2.2.3204 and everything is back to normal.
I would suggest always writing down the current version number before updating.
