Siraya Tech Fibreheart PET-CF profile for e3 v3?
Hi i wondered if anyone had experience with this filament and had any suggestions advice to offer? Thanks in advance. ,!
Hi!
I didn’t use this filament, but I would recommend calibrating it by yourself to check how it works with your printer and favorite settings.
Print quality depends not only on the filament profile itself, but also on the individual printer. Sometimes even two identical printer models can produce different results with the same filament due to variations in calibration, wear, environment, and hardware tolerances.
Creating your own profile will help you get the best results from your specific printer and spool of filament.
You can find all the recommended calibration steps here:
Calibration Tutorial | Creality Wiki
Once you’ve completed the calibration, you’ll have a profile that is tailored to your printer and should produce much more consistent results.
Best regards!
Krzysztof
Hello !
Technically, you could print it with the Ender 3V3..
However, you may have to check your nozzle. PET-CF is an abrasive filament so it may damage the nozzle way faster than PLA or classic PETG
And of course, make sure to avoid any cool breeze while printing as the Ender 3V3 doesn’t have an enclosure (may be hard to avoid warping by the way)
And if you can, dry the filament before printing for a few hours at least
Thanks for that good advice, will do!
Cheers :slight_smile:
Thank you, for that advuce, yes, i might have to get an air dryer, just threw out my old enclosure the other day :frowning:
Hooefully the stock e3 v3 nozzle is okay .
