Hello,
in Creality Print V3 is the possibilityto place text on or in the surface (embossed or engraved – out or in).
This possibility is missing in Version 4!
I miss this option see picture Version 4
I have this version 4.3.7.6699 The text function is still there…
I have deinstall and install again, but I see only what you see in my picture. I have install the Version like you.
Yes Text is working, but only in embossed, also on the top of the surface.
Can you make a picture like me, please?
If you say it’s working then I don’t understand what problem you are having…
I want in engraved mode– like in version 3 –, inside the Surface, like inside a ring.
Embossed is outside of the a surfce, you can touch this.
ok… Sorry. I see what you mean now. You are right…! I tried to do that in Creality Print but it won’t accept a negative number for engraving. I have used Tinkercad to do that kind of stuff. You can adjust text to go below the surface… It might be helpful for what you are doing…
Ok, was a missunderstandig between us.
In Version was working fine.
Wish you a nice day.
